Introdução
The purpose of this guide is to provide step-by-step instructions for replacing your hard drive. For this process you will need a Phillips #00 screwdriver.
Peças
Não são necessárias peças.
  1. Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Locate the hard drive cover on the bottom, left-hand corner of your laptop.
    • Using a Phillips #00 screwdriver, remove both 4mm screws.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Lift the cover to reveal the old hard drive.
    • Lift the cover to reveal the old hard drive.
    • Carefully detach the hard drive from the SATA/Power connector.
  4. After removing the old hard drive, place the new hard drive into the bay, and  firmly reattach it to the SATA/Power connector.
    • After removing the old hard drive, place the new hard drive into the bay, and firmly reattach it to the SATA/Power connector.
Conclusão
Daniel Johnson
102 reputação
4 Guides authored
Equipe
Cal Poly, Team 17-6, Regan Spring 2013 Membro de Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Membros
11 Guides authored
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Todo: 1,574
