Ir para o conteúdo principal
Toshiba Satellite A105-S4284 RAM Replacement
O que você precisa
  1. Toshiba Satellite A105-S4284 RAM Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A105-S4284 RAM Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Toshiba Satellite A105-S4284 RAM Replacement, RAM: passo 2, imagem 1 %32 Toshiba Satellite A105-S4284 RAM Replacement, RAM: passo 2, imagem 2 %32
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. Toshiba Satellite A105-S4284 RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite A105-S4284 RAM Replacement: passo 3, imagem 2 %32
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Toshiba Satellite A105-S4284 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite A105-S4284 RAM Replacement: passo 4, imagem 2 %32 Toshiba Satellite A105-S4284 RAM Replacement: passo 4, imagem 3 %32
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
Conclusão
Uma outra pessoa concluiu este guia.
pfedigan
Membro desde: 04/12/13
11 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 2-23, Maness Spring 2013 Membro de Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
Membros da 4
Autoria de 13 guias
Um comentário
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,105
