Introdução
If your keys are not typing anything or the way they should, then check this guide to see how to safely remove and replace the keyboard input device on the computer. It will also contain detailed pictures on what to expect and watch out for, such as ribbons or wires.
Peças
Não são necessárias peças.
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Remove the lower half of the laptop and lay upper half on its top.
    • Remove the lower half of the laptop and lay upper half on its top.
  3. Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case. Remove the speakers from the case being careful of the wires.
    • Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case.
    • Remove the speakers from the case being careful of the wires.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. The wires for the speakers are color coded.The red and black  wires are for the right speaker, and the black and white wires are for the left speaker.
    • The wires for the speakers are color coded.The red and black wires are for the right speaker, and the black and white wires are for the left speaker.
  6. Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  7. Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker. Use the plastic opening tool to pop off tabs along the length of this panel. This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  8. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver. Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  9. Lift the keyboard gently from the side closest the screen. Pull out the ribbon connecting the keyboard to the laptop. Pull out the ribbon connecting the keyboard to the laptop.
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
pfedigan
11 reputação
4 Guides authored
Equipe
Cal Poly, Team 2-23, Maness Spring 2013 Membro de Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Todo: 1,148
