Ir para o conteúdo principal
Toshiba Satellite A105-S4284 Battery Replacement
  1. Toshiba Satellite A105-S4284 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A105-S4284 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Conclusão
Utsav Shrestha
Membro desde: 04/17/13
82 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 2-23, Maness Spring 2013 Membro de Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 Membros
Autoria de 13 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 7,211
