Ir para o conteúdo principal
Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement
O que você precisa
  1. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Battery: passo 1, imagem 2 %32
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, imagem 1 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, imagem 2 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 2, imagem 3 %32
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): passo 3, imagem 1 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement, Optical Disk Drive (DVD/CD-ROM): passo 3, imagem 2 %32
    • Turn the laptop around with the battery slot facing away from you.
    • Remove the 5.0 mm screw that is holding the optical disk drive internally in place using the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, imagem 1 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, imagem 2 %32 Toshiba Satellite A105-S4074 Optical Disk Drive (DVD/CD-ROM) Replacement: passo 4, imagem 3 %32
    • Turn the laptop back over (cover-side up) with the optical disk drive on the right side.
    • With the plastic opening tool, pry the drive out from the top.
    • Using the opening tool, pull the drive out of the drive bay.
Conclusão
To reassemble your device after replacing the DVD SuperMulti drive, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Ryan Bortnick
Membro desde: 03/20/17
722 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 559
