Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
Hold the release switch and pull out the battery towards you.
Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
Uma outra pessoa concluiu este guia.
