Ir para o conteúdo principal
Toshiba Satellite 2435-S255 Battery Replacement
  1. Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: passo 1, imagem 1 %32 Toshiba Satellite 2435-S255 Battery Replacement, Removing the Latch: passo 1, imagem 2 %32
    • The latch on this is tricky. Fortunately, it’s the only thing you have to deal with.
    • First, slide the latch until you hit resistance. At this point, you have two options.
    • You can either keep pushing the latch until the battery pops out. . .
    • or you can start prying the battery out while pushing the latch (as shown in the second picture above).
  2. Toshiba Satellite 2435-S255 Battery Replacement, Remove the Battery: passo 2, imagem 1 %32
    • Just lift the battery up and out, making sure to lift from the end near the latch.
    • Now the battery is out! To put it back, just insert it back in from the same angle you took it out on.
Conclusão
Jonathan Lancey
Membro desde: 10/22/14
1 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-5, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-5, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G5
3 Membros
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 289
