Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
Open the laptop and remove the two highlighted screws using a PH 0 screw bit.
Take the spudger and insert it between the screen and plastic frame
Tilt the spudger towards you until your hear a click, this means that a clasp has been released
Do this process along the right side, going up, across the frame, and back down to the left side.
Once all of the clasps have been released, the screen should be able to swivel back and forth from the bottom frame.
Place a hand on either side of the plastic frame, and lift up and away from the screen to release the last two hinges on the left side of the screen.
Remove the two screws holding the screen to the frame using the PH 0 screwdriver bit.
Remove the six screws along the outside of the screen using the PH 0 screwdriver bit.
Next remove the screw holding down the white wire using the PH 0 screwdriver bit.
Place the edge of the spudger against the edge of the connector.
Push towards the right side of the frame with a light force until the cable comes loose.
To remove the ribbon cable, peel away the ESD tape.
Hold one side of the tape on the cable, and gently pull down along the screen.
