Ir para o conteúdo principal
Toshiba Satellite 2430-S255 Battery Replacement
  1. Toshiba Satellite 2430-S255 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery locking mechanism on the back side of the laptop. It is labeled with a lock and unlock symbol to indicate its function. The mechanism also has a serrated texture to increase grip.
  2. Toshiba Satellite 2430-S255 Battery Replacement: passo 2, imagem 1 %32
    • Place your left hand on the locking mechanism and slide it all the way to the left. This will move it into the unlocked position. While holding the mechanism in the unlocked position place another finger in the cavity to the right of the locking mechanism.
  3. Toshiba Satellite 2430-S255 Battery Replacement: passo 3, imagem 1 %32
    • Pulling up with your right hand while the locking mechanism in in the unlocked position will release the battery from its socket.
Conclusão
Jacob Zuliani
Membro desde: 03/19/18
147 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S6-G5, Bernier Spring 2018 Membro de UMass Dartmouth, Team S6-G5, Bernier Spring 2018
UMASSD-BERNIER-S18S6G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 250
