Ferramentas
Peças
Nenhum componente especificado.
Placing your finger on the raised grip, push the battery casing to the right. It will slide over.
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Using a Phillips Screwdriver, unscrew and remove the one F4 screw closest to the center of the laptop.
Quase terminado!
Conclusão
