Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
Slide the white ribbon connector up and lift the ribbon out of it.
