Ir para o conteúdo principal
Toshiba Satellite 1805-S177 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Toshiba Satellite 1805-S177 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Stick a spudger in one of the sides of the top panel. Lift slowly from one side to the other and it will pop off.
  2. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, imagem 2 %32 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 2, imagem 3 %32
    • Using an Phillips screwdriver, unscrew and remove two screws labeled B2.6.
  3. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 3, imagem 1 %32
    • Using your hands, lift keyboard up toward you, starting from the edge closest to the screen.
    • The keyboard is still connected to the laptop by a ribbon. Place the keyboard gently on top of the trackpad, keys side down.
  4. Toshiba Satellite 1805-S177 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite 1805-S177 Keyboard Replacement: passo 4, imagem 2 %32
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Slide the white ribbon connector up and lift the ribbon out of it.
Conclusão
Hannah
Membro desde: 06/24/10
227 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 3-5, Johann Summer 2010 Membro de Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,712
