Ir para o conteúdo principal
Toshiba Satellite 1805-S177 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Toshiba Satellite 1805-S177 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Look at the bottom of the laptop. Using a Phillips screwdriver, unscrew and remove the screw labeled F4, located on the cover of the hard drive.
    • The hard drive is located next to the CD drive.
  2. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 2, imagem 1 %32
    • Placing your finger on the raised grip, push up on the hard drive cover. This will remove the hard drive cover from the laptop.
  3. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 3, imagem 2 %32
    • Using a Phillips screwdriver, unscrew and remove the screw surrounded by the white plastic.
  4. Toshiba Satellite 1805-S177 Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the white plastic out toward you. This should remove the hard drive tray from the laptop.
    • This laptop does not have a hard drive, so the tray is empty. On your computer, the hard drive should be in the tray.
Conclusão
Hannah
Membro desde: 06/24/10
227 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 3-5, Johann Summer 2010 Membro de Cal Poly, Team 3-5, Johann Summer 2010
CPSU-JOHANN-R10S3G5
4 Membros
Autoria de 24 guias
Um comentário
How can I run a cd if I can't remember my hdd password on my toshiba l645 computer
Vera Hess - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 4,241
