Ir para o conteúdo principal
Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement
O que você precisa
  1. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Battery: passo 1, imagem 1 %32
    • The battery is located on the front right corner of the laptop.
  2. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 2, imagem 1 %32
    • With one finger on the raised grip, slide the latch towards the front of the laptop.
  3. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 3, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 3, imagem 2 %32
    • Pull the battery out towards the side.
  4. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 4, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 4, imagem 2 %32
    • Lift the battery straight up, out of the computer.
  5. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Lower Case: passo 5, imagem 1 %32
    • Unscrew all of the visible screws on the bottom of the laptop.
    • The screws circled are not necessary to remove.
    • Keeping track of which hole each screw goes in will speed up reassembly.
  6. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 6, imagem 1 %32
    • Unscrew the screws located beneath the battery.
  7. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: passo 7, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: passo 7, imagem 2 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Keyboard: passo 7, imagem 3 %32
    • Using a set of case opening tools, pry open the left and right sides of the black plastic strip above the keyboard.
    • Fully detach the strip.
  8. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 8, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 8, imagem 2 %32
    • Unscrew the two screws near the top of the keyboard.
  9. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 9, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 9, imagem 2 %32
    • Lift the keyboard by holding the middle top of the keyboard.
    • The keyboard is still connected by a ribbon cable to the motherboard.
  10. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 10, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 10, imagem 2 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 10, imagem 3 %32
    • Carefully pull upwards on the ribbon cable to detach.
    • Remove keyboard.
  11. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: passo 11, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Power Button Circuit Board: passo 11, imagem 2 %32
    • Unscrew the screws on either side of the power button circuit board.
  12. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 12, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 12, imagem 2 %32
    • Pull upward on the small white ribbon cable to detach from circuit board.
  13. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Optical Drive: passo 13, imagem 1 %32
    • Unscrew the screw located on the left side of the optical drive near the heat sink cover in the middle of the laptop.
  14. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 14, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 14, imagem 2 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 14, imagem 3 %32
    • Using spudger, push the optical drive out to the right.
  15. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: passo 15, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, Upper Case: passo 15, imagem 2 %32
    • Disconnect both speaker connectors located near the center of the laptop.
  16. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 16, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 16, imagem 2 %32
    • Unscrew all visible screws on the heat sink shield.
  17. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 17, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 17, imagem 2 %32
    • Disconnect the monitor connector.
  18. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 18, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 18, imagem 2 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 18, imagem 3 %32
    • Starting from the front right corner pry apart the black bottom from the gray top.
  19. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 19, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 19, imagem 2 %32
    • Set aside the top half.
  20. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: passo 20, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement, CPU Fan and Heatsink: passo 20, imagem 2 %32
    • Unscrew the remaining screws on the heatsink and fan brackets.
  21. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 21, imagem 1 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 21, imagem 2 %32 Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 21, imagem 3 %32
    • Disconnect the fan power connector.
    • Remove the heatsink and fan.
    • Check the heatsink fins and fan for any dust build-up. If any is found use compressed air to clean.
  22. Toshiba Satellite 1415-S105 CPU Fan and Heatsink Replacement: passo 22, imagem 1 %32
    • Clean the old thermal paste off the CPU and heatsink.
    • Use a q tip to remove the majority of the thermal paste.
    • Use an isopropyl alcohol soaked q tip to further clean remaining thermal paste.
    • Dry and clean both surfaces with another q-tip.
    • Once completely clean, apply a rice grain sized amount of new thermal paste to the CPU and reattach the heatsink and fan.
Conclusão
Uma outra pessoa concluiu este guia.
Kiril Lange
Membro desde: 09/22/14
943 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 3-2, Brown Fall 2014 Membro de USF Tampa, Team 3-2, Brown Fall 2014
USFT-BROWN-F14S3G2
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 953
