Ir para o conteúdo principal
Toshiba SD-K740 Motherboard Replacement
O que você precisa
  1. Toshiba SD-K740 Motherboard Replacement, Top Panel: passo 1, imagem 1 %32
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Motherboard Replacement: passo 2, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 2, imagem 2 %32
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Motherboard Replacement: passo 3, imagem 1 %32
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Motherboard Replacement, Front Panel: passo 4, imagem 1 %32
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Motherboard Replacement: passo 5, imagem 1 %32
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Motherboard Replacement: passo 6, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 6, imagem 2 %32
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove the black tie holding the two rear ribbon cables together by untwisting it.
  8. Toshiba SD-K740 Motherboard Replacement: passo 8, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove the first of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  9. Toshiba SD-K740 Motherboard Replacement: passo 9, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the second of two multipin cables connected to the Left-Side Motherboard (Green) by pulling vertically.
  10. Toshiba SD-K740 Motherboard Replacement: passo 10, imagem 1 %32
    • Pull the two cables to the right to disentangle from the disc drive.
    • Do not tug, pull, or force the cable. It should slide out with minimal force.
  11. Toshiba SD-K740 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the first of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  12. Toshiba SD-K740 Motherboard Replacement: passo 12, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the second of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  13. Toshiba SD-K740 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the third of three ribbon cables on the left hand side of the disc drive by pulling vertically.
  14. Toshiba SD-K740 Motherboard Replacement: passo 14, imagem 1 %32
    • Flip the DVD player so it is resting on its front face (so the back is facing you).
    • Remove the four .320 inch screws holding the motherboard to its casing.
  15. Toshiba SD-K740 Motherboard Replacement: passo 15, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 15, imagem 2 %32
    • Push the motherboard forward a few inches to detach it from the casing.
  16. Toshiba SD-K740 Motherboard Replacement: passo 16, imagem 1 %32 Toshiba SD-K740 Motherboard Replacement: passo 16, imagem 2 %32
    • Lift the motherboard from the rear and pull backward (towards you) to remove it entirely from the case.
Conclusão
Joe Murphy
Membro desde: 01/20/11
542 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 1-16, Amido Winter 2011 Membro de Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 954
