Ir para o conteúdo principal
Toshiba SD-K740 Disc Drive Replacement
O que você precisa
  1. Toshiba SD-K740 Disc Drive Replacement, Top Panel: passo 1, imagem 1 %32
    • Unplug the DVD player before beginning.
    • Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba SD-K740 Disc Drive Replacement: passo 2, imagem 1 %32 Toshiba SD-K740 Disc Drive Replacement: passo 2, imagem 2 %32
    • Turn the DVD player on its side.
    • Remove the 7.7 mm screw.
    • Flip the DVD player onto its other side.
  3. Toshiba SD-K740 Disc Drive Replacement: passo 3, imagem 1 %32
    • Flip the DVD player over onto its front face.
    • Remove the back panel by lifting up and pulling it towards yourself.
  4. Toshiba SD-K740 Disc Drive Replacement, Front Panel: passo 4, imagem 1 %32
    • Flip the DVD player so its top is sitting on your working surface.
    • Lift and push away the two tabs located in the middle of the player.
    • The front panel will not detach during this step, so do not force it.
  5. Toshiba SD-K740 Disc Drive Replacement: passo 5, imagem 1 %32
    • Flip the DVD player on its side.
    • Lift and slide forward the single tab on the side.
  6. Toshiba SD-K740 Disc Drive Replacement: passo 6, imagem 1 %32 Toshiba SD-K740 Disc Drive Replacement: passo 6, imagem 2 %32
    • Grasp the front panel and pull forward to your right to remove it.
  7. Toshiba SD-K740 Disc Drive Replacement, Disc Drive: passo 7, imagem 1 %32 Toshiba SD-K740 Disc Drive Replacement, Disc Drive: passo 7, imagem 2 %32
    • Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
  8. Toshiba SD-K740 Disc Drive Replacement: passo 8, imagem 1 %32 Toshiba SD-K740 Disc Drive Replacement: passo 8, imagem 2 %32
    • Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
  9. Toshiba SD-K740 Disc Drive Replacement: passo 9, imagem 1 %32 Toshiba SD-K740 Disc Drive Replacement: passo 9, imagem 2 %32
    • Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
  10. Toshiba SD-K740 Disc Drive Replacement: passo 10, imagem 1 %32
    • Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
  11. Toshiba SD-K740 Disc Drive Replacement: passo 11, imagem 1 %32
    • Lift disc drive vertically to remove.
Conclusão
Uma outra pessoa concluiu este guia.
Joe Murphy
Membro desde: 01/20/11
542 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 1-16, Amido Winter 2011 Membro de Cal Poly, Team 1-16, Amido Winter 2011
CPSU-AMIDO-W11S1G16
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 2,642
