Ir para o conteúdo principal
Toshiba Qosmio X775-3DV80 Keyboard Replacement
O que você precisa
  1. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 2, imagem 2 %32
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Optical Drive: passo 4, imagem 1 %32
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 6, imagem 2 %32
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
  7. Toshiba Qosmio X775-3DV80 Keyboard Replacement, RAM: passo 7, imagem 1 %32
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  8. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 8, imagem 1 %32
    • Using a spudger or plastic opening tool, pry off the service panel.
  9. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, imagem 2 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 9, imagem 3 %32
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
  10. Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: passo 10, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement, Keyboard: passo 10, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove all the remaining fourteen screws from the bottom case of the laptop.
    • The service panel should already be removed.
  11. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 11, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 11, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the five screws under the service panel.
    • Remove the retaining clip.
  12. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 12, imagem 1 %32
    • Using a spudger, pry the keyboard from the top panel of the laptop.
    • Make sure to pry it off all around.
  13. Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, imagem 1 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, imagem 2 %32 Toshiba Qosmio X775-3DV80 Keyboard Replacement: passo 13, imagem 3 %32
    • Disconnect the two ribbon cables connecting the keyboard to the laptop.
    • Unplug the connector on the bottom of the laptop.
Conclusão
Jesse Adam Ory
Membro desde: 03/24/19
745 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S2-G1, Bailey Spring 2019 Membro de UMass Dartmouth, Team S2-G1, Bailey Spring 2019
UMASSD-BAILEY-S19S2G1
Membros da 4
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Duração total: 497
