Ir para o conteúdo principal
Toshiba Portege Z835-P330 Solid-State Drive Replacement
O que você precisa
  1. Toshiba Portege Z835-P330 Solid-State Drive Replacement, Solid-State Drive: passo 1, imagem 1 %32
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 2, imagem 1 %32
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 3, imagem 1 %32
    • Peel off hard cover to expose interior of device.
  4. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 4, imagem 1 %32
    • Find the solid-state drive located below the battery, and next to the RAM.
    • Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Solid-State Drive Replacement: passo 5, imagem 1 %32
    • Pull the solid-state drive from its socket
    • The solid-state drive should automatically pop-up from its housing once the screws are removed.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,202
