Ir para o conteúdo principal
Toshiba Portege Z835-P330 Internal Cooling Fan Replacement
O que você precisa
  1. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement, Internal Cooling Fan: passo 1, imagem 1 %32
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: passo 2, imagem 1 %32
    • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  3. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: passo 3, imagem 1 %32
    • Peel off hard cover to expose interior of device
  4. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: passo 4, imagem 1 %32
    • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  5. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: passo 5, imagem 1 %32
    • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  6. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: passo 6, imagem 1 %32
    • Lift the internal cooling fan to remove the fan from the device
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 661
