Ir para o conteúdo principal
Toshiba Portege Z835-P330 Battery Replacement
O que você precisa
  1. Toshiba Portege Z835-P330 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Battery Replacement: passo 2, imagem 1 %32
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Battery Replacement: passo 3, imagem 1 %32
    • Peel off hardcover to expose interior of device.
    • Force may be required but hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Battery Replacement: passo 4, imagem 1 %32
    • Remove the six 1 mm screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Battery Replacement: passo 5, imagem 1 %32
    • Remove the white plug connected to the battery by gently pulling it out of the socket.
    • Plug should easily detach without force.
  6. Toshiba Portege Z835-P330 Battery Replacement: passo 6, imagem 1 %32
    • Lift battery up by its sides, and it should easily come off.
Conclusão
6 comentários
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Jim Flattery - Responder
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
pat_brady_pb@yahoo.com - Responder
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Jim Flattery -
Could anyone please tell me which type of screws are these ?
lourencopintodasilva - Responder
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
Jim Flattery -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 34
Duração total: 4,679
