Ir para o conteúdo principal
Toshiba Portege R835-P88 Screen Replacement
O que você precisa
  1. Toshiba Portege R835-P88 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Remove the battery by pressing the two buttons inward and pulling the battery out.
  2. Toshiba Portege R835-P88 Screen Replacement: passo 2, imagem 1 %32
    • Remove the end caps located on the left and right corners below the screen.
  3. Toshiba Portege R835-P88 Screen Replacement: passo 3, imagem 1 %32
    • Remove the square rubber caps on top of the screws
    • Remove the 4 mm screws at the top
    • remove the two 6 mm screws that were under the chrome caps at the bottom.
  4. Toshiba Portege R835-P88 Screen Replacement: passo 4, imagem 1 %32
    • Remove the plastic bezel by lightly prying on it. It will pop when it starts to come loose.
  5. Toshiba Portege R835-P88 Screen Replacement: passo 5, imagem 1 %32 Toshiba Portege R835-P88 Screen Replacement: passo 5, imagem 2 %32
    • Remove tape from around cord attached to the bottom of the screen.
    • Place the screen on top of the keyboard
  6. Toshiba Portege R835-P88 Screen Replacement: passo 6, imagem 1 %32 Toshiba Portege R835-P88 Screen Replacement: passo 6, imagem 2 %32 Toshiba Portege R835-P88 Screen Replacement: passo 6, imagem 3 %32
    • Remove the cord from the screen by cutting the tape where the two fittings meet. After that pull them apart.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 19
Ao todo: 494
