Ir para o conteúdo principal
Toshiba Portege R835-P88 Optical Drive Replacement
O que você precisa
  1. Toshiba Portege R835-P88 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Start by removing the battery.
  2. Toshiba Portege R835-P88 Optical Drive Replacement: passo 2, imagem 1 %32 Toshiba Portege R835-P88 Optical Drive Replacement: passo 2, imagem 2 %32
    • Start by removing the back cover by removing the screws, revealing the Optical Drive. Remove the 1 cm screws to remove. Then use the spudger to pry the back off.
  3. Toshiba Portege R835-P88 Optical Drive Replacement: passo 3, imagem 1 %32
    • After the cover is removed, remove the screws that hold the Drive. It has 3, 1 cm screws holding it down.
  4. Toshiba Portege R835-P88 Optical Drive Replacement: passo 4, imagem 1 %32
    • Take the 2, .5 cm screws out of the drive line. Once this is complete, you have successfully taken out the Optical Drive.
Conclusão
Colt Cates
Membro desde: 01/19/17
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 663
