Ir para o conteúdo principal
Toshiba Portege R700-S1312 RAM Replacement
O que você precisa
  1. Toshiba Portege R700-S1312 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery on the backside of the laptop. The battery is usually located at the bottom.
  2. Toshiba Portege R700-S1312 RAM Replacement: passo 2, imagem 1 %32
    • Locate the battery lock button and push it towards the unlock position.
  3. Toshiba Portege R700-S1312 RAM Replacement: passo 3, imagem 1 %32 Toshiba Portege R700-S1312 RAM Replacement: passo 3, imagem 2 %32 Toshiba Portege R700-S1312 RAM Replacement: passo 3, imagem 3 %32
    • Hold the next lock in the unlock position. Simultaneously pull the battery towards you.
  4. Toshiba Portege R700-S1312 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Flip the laptop over.
  5. Toshiba Portege R700-S1312 RAM Replacement: passo 5, imagem 1 %32
    • Using a Phillips #00 Screwdriver unscrew the 2 40mm screws that are located on the plate covering the RAM.
  6. Toshiba Portege R700-S1312 RAM Replacement: passo 6, imagem 1 %32
    • Remove the plate covering the RAM.
  7. Toshiba Portege R700-S1312 RAM Replacement: passo 7, imagem 1 %32
    • Pull the sides holding the RAM in place until there is a slight pop.
  8. Toshiba Portege R700-S1312 RAM Replacement: passo 8, imagem 1 %32
    • The RAM stick will lift up on its own. Simply remove it.
  9. Toshiba Portege R700-S1312 RAM Replacement: passo 9, imagem 1 %32
    • Place new RAM into the RAM drive and gently press until there is a slight pop.
Conclusão
To reassemble your device, simply follow steps 1-3 in reverse order.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 570
