Introdução
In this guide we will be dissembling the device so that we can replace the fan in the laptop.
  1. Make sure the device is off to prevent data loss. Slide both latches to the unlocked position to release the battery.
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Pull up on the back casing and remove it.
    • Pull up on the back casing and remove it.
  5. Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  6. Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
Conclusão
JRJones
121 reputação
5 Guides authored
Equipe
Cal Poly, Team 2-19, Maness Spring 2013 Membro de Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 Membros
5 Guides authored
Don't forget the silver compound when re-assembling
Graham Smith - Responder
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Todo: 2,989
