Ir para o conteúdo principal
Toshiba Portege R205-S209 Keyboard Replacement
O que você precisa
  1. Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Flip the laptop over. Keep the front end facing away from you, so the battery appears at the top.
  2. Toshiba Portege R205-S209 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the locking mechanism to the right and hold.
  3. Toshiba Portege R205-S209 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 3, imagem 2 %32
    • While holding the locking mechanism to the right, insert your finger into the tab and lift up.
  4. Toshiba Portege R205-S209 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 4, imagem 2 %32
    • Remove battery by lifting upward.
  5. Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Remove the 4mm Phillips head screw in the middle of the laptop with a Phillips head #00 screwdriver.
  6. Toshiba Portege R205-S209 Keyboard Replacement: passo 6, imagem 1 %32
    • Flip the laptop over and open the display.
  7. Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the plastic casing above the keyboard with the plastic opening tool. Start at the edges of the plastic casing and move toward the middle.
  8. Toshiba Portege R205-S209 Keyboard Replacement: passo 8, imagem 1 %32
    • Lift up and remove the plastic casing.
  9. Toshiba Portege R205-S209 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 9, imagem 2 %32
    • Remove the 4mm Phillips head screws at the top of the keyboard at both ends, using the Phillips head #00 screwdriver.
  10. Toshiba Portege R205-S209 Keyboard Replacement: passo 10, imagem 1 %32
    • Lift up the keyboard, but do not remove it completely.
    • The keyboard is still attached to the computer, so be very careful when lifting it up.
  11. Toshiba Portege R205-S209 Keyboard Replacement: passo 11, imagem 1 %32 Toshiba Portege R205-S209 Keyboard Replacement: passo 11, imagem 2 %32
    • Gently pull the ribbon toward the screen until it slides out of the connecting point.
    • Remove keyboard.
Conclusão
Leah Catania
Membro desde: 10/12/15
83 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 323
