Ir para o conteúdo principal
Toshiba Portege R205-S209 Heatsink Fan Replacement
O que você precisa
  1. Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement, Heatsink Fan: passo 1, imagem 3 %32
    • With the laptop flipped over, unlock the mechanism that is shown in red.
    • Lift and remove the battery out of the device.
  2. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 2, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 2, imagem 2 %32
    • Remove the accessory plate by unscrewing the single Phillips #0 screw and lifting up the panel.
  3. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 3, imagem 3 %32
    • Remove the 18 Phillips #0 screws that keep the bottom plate attached to the outer portion of the laptop.
  4. Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 1 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 2 %32 Toshiba Portege R205-S209 Heatsink Fan Replacement: passo 4, imagem 3 %32
    • Remove the 2 Phillips #0 screws holding the heat sink in place.
    • Detach the heatsink fan from the motherboard by removing the clip that connects them together and pulling away from the laptop horizontally.
Conclusão
Jason Sizen
Membro desde: 04/04/19
193 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Crossman Spring 2019 Membro de IUPUI, Team S1-G2, Crossman Spring 2019
IUPUI-CROSSMAN-S19S1G2
3 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 193
