Ir para o conteúdo principal
Toshiba Portege M400 Touchpad Replacement
O que você precisa
  1. Toshiba Portege M400 Touchpad Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Touchpad Replacement: passo 2, imagem 1 %32
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Touchpad Replacement: passo 3, imagem 1 %32 Toshiba Portege M400 Touchpad Replacement: passo 3, imagem 2 %32 Toshiba Portege M400 Touchpad Replacement: passo 3, imagem 3 %32
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Touchpad Replacement: passo 4, imagem 1 %32 Toshiba Portege M400 Touchpad Replacement: passo 4, imagem 2 %32
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
  5. Toshiba Portege M400 Touchpad Replacement, Touchpad: passo 5, imagem 1 %32 Toshiba Portege M400 Touchpad Replacement, Touchpad: passo 5, imagem 2 %32
    • Use a plastic opening tool to carefully remove the cover of the touchpad.
    • Remove the one 1/2" inch screw on the backside of the laptop.
  6. Toshiba Portege M400 Touchpad Replacement: passo 6, imagem 1 %32 Toshiba Portege M400 Touchpad Replacement: passo 6, imagem 2 %32
    • Gently pull up the touch-pad piece and lay it upside down.
    • The touch-pad will still be connected to the computer.
  7. Toshiba Portege M400 Touchpad Replacement: passo 7, imagem 1 %32 Toshiba Portege M400 Touchpad Replacement: passo 7, imagem 2 %32
    • Pull back the tab to disconnect the touchpad to the laptop.
Conclusão
Equipe
Cal Poly, Team 4-17, Maness Spring 2013 Membro de Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 15
Duração total: 1,205
