Ir para o conteúdo principal
Toshiba Portege M400 Motherboard Replacement
O que você precisa
  1. Toshiba Portege M400 Motherboard  Replacement, Motherboard: passo 1, imagem 1 %32
    • Using the plastic opening tool, remove the plastic hinge cover on the back of the laptop. Use caution not to damage this plastic cover.
  2. Toshiba Portege M400 Motherboard  Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, remove the plastic cover directly above the keyboard. Make sure to start from the corners of the plastic cover.
  3. Toshiba Portege M400 Motherboard  Replacement: passo 3, imagem 1 %32
    • Using the #1 Phillips head screwdriver, remove the two 3.8mm screws.
  4. Toshiba Portege M400 Motherboard  Replacement: passo 4, imagem 1 %32
    • Remove the keyboard, make sure you gently remove any ribbon cables holding it to the rest of the computer. Bending or crimping a ribbon cable can break the device.
  5. Toshiba Portege M400 Motherboard  Replacement: passo 5, imagem 1 %32 Toshiba Portege M400 Motherboard  Replacement: passo 5, imagem 2 %32
    • Use a small phillips screwdriver to remove both metal shields as depicted.
  6. Toshiba Portege M400 Motherboard  Replacement: passo 6, imagem 1 %32 Toshiba Portege M400 Motherboard  Replacement: passo 6, imagem 2 %32
    • After removing the second metal covering you will remove the RAM compartment.
    • Simply pull apart the metal fasteners on the side; the RAM should pop out for removal.
  7. Toshiba Portege M400 Motherboard  Replacement: passo 7, imagem 1 %32 Toshiba Portege M400 Motherboard  Replacement: passo 7, imagem 2 %32 Toshiba Portege M400 Motherboard  Replacement: passo 7, imagem 3 %32
    • Disconnect the wire from the exposed wireless card.
    • Pry open the top of the laptop and gently remove and disconnect the wires as shown.
  8. Toshiba Portege M400 Motherboard  Replacement: passo 8, imagem 1 %32 Toshiba Portege M400 Motherboard  Replacement: passo 8, imagem 2 %32
    • Remove the screws attaching the motherboard to the plastic housing.
    • Lift off the motherboard. Once it is free of screws and you're done!
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 1,357
