Ir para o conteúdo principal
Toshiba Portege M400 Keyboard Replacement
O que você precisa
  1. Toshiba Portege M400 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Remove the front face plate with a plastic opening tool.
    • Unscrew and remove the two 3.8mm screws labeled B3 with the #1 Phillips screwdriver.
  2. Toshiba Portege M400 Keyboard Replacement: passo 2, imagem 1 %32
    • Lift the keyboard toward you starting from the edge closest to the screen.
    • This ribbon still connects the taptor to the keyboard.
    • Gently place the keyboard on top of the track pad with the keys upside down.
  3. Toshiba Portege M400 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Portege M400 Keyboard Replacement: passo 3, imagem 2 %32 Toshiba Portege M400 Keyboard Replacement: passo 3, imagem 3 %32
    • Find the white ribbon connector (where the keyboard is still attached to the rest of the laptop).
    • Remove the screw on the metal plate that keeps the ribbon from sliding out.
    • Gently remove the metal plate and set it aside.
  4. Toshiba Portege M400 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Portege M400 Keyboard Replacement: passo 4, imagem 2 %32
    • Dislodge the white ribbon connector from the two clips holding it in place using the plastic opening tools.
    • Pull out the white ribbon connector with your fingers.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 4-17, Maness Spring 2013 Membro de Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 1,054
