Ir para o conteúdo principal
Toshiba Portege M400 CD/DVD Drive Replacement
O que você precisa
  1. Toshiba Portege M400 CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32
    • Make sure your computer is securely latched and closed.
    • Locate the CD drive on the right side of your Toshiba Portege M400 laptop and find a small hole right next to the CD drive button.
  2. Toshiba Portege M400 CD/DVD Drive Replacement: passo 2, imagem 1 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the tweezers, insert them into the small hole next to the CD drive button.
  3. Toshiba Portege M400 CD/DVD Drive Replacement: passo 3, imagem 1 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 3, imagem 2 %32
    • Push the tweezers back into the hole and grab the CD drive door with the other tweezers' appendage.
    • Pull the CD door out carefully to remove the broken or jammed disk.
    • Note: If the CD door still does not open, move on to the next step to see how to remove the CD drive entirely.
  4. Toshiba Portege M400 CD/DVD Drive Replacement: passo 4, imagem 1 %32
    • Flip the laptop over so its on its face.
  5. Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, imagem 1 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, imagem 2 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 5, imagem 3 %32
    • Locate screw as seen on picture
    • Using #1 Philips head screwdriver remove the 3.8mm screw.
  6. Toshiba Portege M400 CD/DVD Drive Replacement: passo 6, imagem 1 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 6, imagem 2 %32
    • Locate the lock switch in the center of the laptop.
    • Locate the tab on the end of the end of the CD Drive.
  7. Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, imagem 1 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, imagem 2 %32 Toshiba Portege M400 CD/DVD Drive Replacement: passo 7, imagem 3 %32
    • Push down on the lock tab and pull on the CD tab simultaneously.
    • Keep pulling on the CD drive tab until the CD drive comes all the way out.
Conclusão
Spencer Dilley
Membro desde: 04/15/13
4 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-17, Maness Fall 2012 Membro de Cal Poly, Team 4-17, Maness Fall 2012
CPSU-MANESS-F12S4G17
1 Membro
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 43
Duração total: 1,394
