Ir para o conteúdo principal
Toshiba Portege M300 Wireless Card Replacement
O que você precisa
  1. Toshiba Portege M300 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Wireless Card Replacement: passo 2, imagem 1 %32 Toshiba Portege M300 Wireless Card Replacement: passo 2, imagem 2 %32
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Wireless Card Replacement: passo 3, imagem 1 %32 Toshiba Portege M300 Wireless Card Replacement: passo 3, imagem 2 %32
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, imagem 1 %32 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, imagem 2 %32 Toshiba Portege M300 Wireless Card Replacement, Wireless Card: passo 4, imagem 3 %32
    • Turn the computer onto the back.
    • Remove the Phillips #0 screw that secures the cover to the rest of the device.
    • One 5.1 mm coarse thread screw.
    • Pull the cover forward to release it.
  5. Toshiba Portege M300 Wireless Card Replacement: passo 5, imagem 1 %32 Toshiba Portege M300 Wireless Card Replacement: passo 5, imagem 2 %32 Toshiba Portege M300 Wireless Card Replacement: passo 5, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two screws on opposite corners of the wireless card.
    • Two 4.0 mm coarse thread screws.
    • Use a plastic opening tool to gently lift the wireless card out while leaving the wire connected.
  6. Toshiba Portege M300 Wireless Card Replacement: passo 6, imagem 1 %32 Toshiba Portege M300 Wireless Card Replacement: passo 6, imagem 2 %32
    • Hold the edges of the wireless card and carefully disconnect the black 3 pin connector.
Conclusão
Alison Wendt
Membro desde: 04/18/13
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-51, Johann Spring 2013 Membro de Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 24
Duração total: 880
