Ir para o conteúdo principal
Toshiba Portege M300 RAM Replacement
O que você precisa
  1. Toshiba Portege M300 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 RAM Replacement: passo 2, imagem 1 %32 Toshiba Portege M300 RAM Replacement: passo 2, imagem 2 %32
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 RAM Replacement: passo 3, imagem 1 %32 Toshiba Portege M300 RAM Replacement: passo 3, imagem 2 %32
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 RAM Replacement, RAM: passo 4, imagem 1 %32 Toshiba Portege M300 RAM Replacement, RAM: passo 4, imagem 2 %32 Toshiba Portege M300 RAM Replacement, RAM: passo 4, imagem 3 %32
    • Turn the computer over onto the back.
    • Use a Phillips head screwdriver to remove the screw holding the RAM cover in place, and lift the cover.
    • One 4.0 mm coarse thread screw.
  5. Toshiba Portege M300 RAM Replacement: passo 5, imagem 1 %32 Toshiba Portege M300 RAM Replacement: passo 5, imagem 2 %32 Toshiba Portege M300 RAM Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to open the silver flaps on either side of the RAM.
    • Once both flaps are released, the RAM should pop up at an angle.
  6. Toshiba Portege M300 RAM Replacement: passo 6, imagem 1 %32 Toshiba Portege M300 RAM Replacement: passo 6, imagem 2 %32
    • Grasp both sides of the RAM and pull to remove it.
Conclusão
Alison Wendt
Membro desde: 04/18/13
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-51, Johann Spring 2013 Membro de Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
3 Membros
Autoria de 18 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,303
