Ir para o conteúdo principal
Toshiba Portege M300 Keyboard Replacement
O que você precisa
  1. Toshiba Portege M300 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Keyboard Replacement: passo 3, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 3, imagem 2 %32
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the rest of the cover by sliding it to the right and lifting the edge.
  6. Toshiba Portege M300 Keyboard Replacement: passo 6, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a Phillips head #00 screwdriver to remove the two silver screws at the top of the keyboard.
    • Two 4.0 mm coarse thread screws.
  7. Toshiba Portege M300 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 7, imagem 2 %32 Toshiba Portege M300 Keyboard Replacement: passo 7, imagem 3 %32
    • Remove the Torx screw holding the left keyboard tab in place, and lift it to release.
    • One Torx T6 fine thread screw.
  8. Toshiba Portege M300 Keyboard Replacement: passo 8, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 8, imagem 2 %32
    • Turn the computer over on to the back.
    • Remove the middle screw with a Phillips head #000 screwdriver.
    • One 7.5 mm fine thread screw.
  9. Toshiba Portege M300 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 9, imagem 2 %32
    • Turn the computer over to the front.
    • Gently pull at the top and bottom to remove the keyboard.
    • Peel off the black tape that holds the connection wire.
  10. Toshiba Portege M300 Keyboard Replacement: passo 10, imagem 1 %32 Toshiba Portege M300 Keyboard Replacement: passo 10, imagem 2 %32
    • Flip the keyboard over and carefully unplug the connection wire.
    • Reverse the steps for proper instillation of the new keyboard.
Conclusão
Alison Wendt
Membro desde: 04/18/13
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-51, Johann Spring 2013 Membro de Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,260
