Ir para o conteúdo principal
Toshiba Portege M300 Hard Drive Replacement
O que você precisa
  1. Toshiba Portege M300 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Portege M300 Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Portege M300 Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Toshiba Portege M300 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Turn the computer over onto the back.
    • Use a Phillips #1 screwdriver to remove the screw from the hard drive cover.
    • Lift and remove the cover.
  5. Toshiba Portege M300 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Portege M300 Hard Drive Replacement: passo 5, imagem 2 %32 Toshiba Portege M300 Hard Drive Replacement: passo 5, imagem 3 %32
    • Carefully remove the hard drive from the IDE cable by pulling on the black connector.
    • Do not pull the orange cable.
  6. Toshiba Portege M300 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Portege M300 Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the two gray rubber covers from both ends of the hard drive.
Conclusão
5 outras pessoas executaram este guia.
Alison Wendt
Membro desde: 04/18/13
135 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 21-51, Johann Spring 2013 Membro de Cal Poly, Team 21-51, Johann Spring 2013
CPSU-JOHANN-S13S21G51
Membros da 3
Autoria de 18 guias
Um comentário
cual es el numero de parte del flex del hdd porfa
Alex De santiago - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 2,424
