Ir para o conteúdo principal
Toshiba Portege 3110CT Fan Replacement
O que você precisa
  1. Toshiba Portege 3110CT Fan Replacement, Fan: passo 1, imagem 1 %32
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Fan Replacement: passo 2, imagem 1 %32
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Fan Replacement: passo 3, imagem 1 %32
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Fan Replacement: passo 4, imagem 1 %32
    • Remove this final screw and lift out the fan
Conclusão
Spencer Gamble
Membro desde: 10/20/16
401 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 6-4, Martin Fall 2016 Membro de UMass Dartmouth, Team 6-4, Martin Fall 2016
UMASSD-MARTIN-F16S6G4
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 10
Duração total: 348
