Ir para o conteúdo principal
Toshiba NB305 Wifi Card Replacement
O que você precisa
  1. Toshiba NB305 Wifi Card Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Wifi Card Replacement: passo 2, imagem 1 %32
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Wifi Card Replacement: passo 3, imagem 1 %32 Toshiba NB305 Wifi Card Replacement: passo 3, imagem 2 %32
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Wifi Card Replacement, Wifi Card: passo 4, imagem 1 %32 Toshiba NB305 Wifi Card Replacement, Wifi Card: passo 4, imagem 2 %32 Toshiba NB305 Wifi Card Replacement, Wifi Card: passo 4, imagem 3 %32
    • Locate the two torx T-6 screws on the back of the laptop and remove them.
    • 6mm Torx T-6 Screws
  5. Toshiba NB305 Wifi Card Replacement: passo 5, imagem 1 %32 Toshiba NB305 Wifi Card Replacement: passo 5, imagem 2 %32
    • Using a spudger pry the panel up.
  6. Toshiba NB305 Wifi Card Replacement: passo 6, imagem 1 %32 Toshiba NB305 Wifi Card Replacement: passo 6, imagem 2 %32
    • Using a spudger pry up and off the two wire connections.
    • Note that the black wire is on the top of the card and the white is the bottom.
  7. Toshiba NB305 Wifi Card Replacement: passo 7, imagem 1 %32 Toshiba NB305 Wifi Card Replacement: passo 7, imagem 2 %32
    • Remove the two Phillips 0 size screws on WIFI card.
    • Once the screws are removed the WIFI card will raise up
  8. Toshiba NB305 Wifi Card Replacement: passo 8, imagem 1 %32 Toshiba NB305 Wifi Card Replacement: passo 8, imagem 2 %32
    • Grip both sides of the wifi card with your hand.
    • Lift up on the card and pull the card out of the slot
Conclusão
Mateo Fontana
Membro desde: 09/14/16
286 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-5, Lacy Fall 2016 Membro de USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 429
