Ir para o conteúdo principal
Toshiba NB305 RAM Replacement
O que você precisa
  1. Toshiba NB305 RAM  Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 RAM  Replacement: passo 2, imagem 1 %32
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 RAM  Replacement: passo 3, imagem 1 %32 Toshiba NB305 RAM  Replacement: passo 3, imagem 2 %32
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 RAM  Replacement, RAM: passo 4, imagem 1 %32
    • The RAM is located underneath the top left panel on the back of the laptop.
    • Remove the captive Phillips-0 screw with a screwdriver.
  5. Toshiba NB305 RAM  Replacement: passo 5, imagem 1 %32 Toshiba NB305 RAM  Replacement: passo 5, imagem 2 %32
    • Using a spudger pry up on the open slit next to the screw.
  6. Toshiba NB305 RAM  Replacement: passo 6, imagem 1 %32 Toshiba NB305 RAM  Replacement: passo 6, imagem 2 %32
    • The RAM is held in place with two clips, one on each side.
    • Using two plastic opening tools (or your fingers) pull two tabs holding RAM outwards.
    • The RAM card will pop up when it is released.
  7. Toshiba NB305 RAM  Replacement: passo 7, imagem 1 %32 Toshiba NB305 RAM  Replacement: passo 7, imagem 2 %32
    • Pull the RAM straight out of the slot.
Conclusão
Nuri Chung
Membro desde: 10/25/16
377 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 5-5, Lacy Fall 2016 Membro de USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
3 Membros
Autoria de 15 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 683
