Introdução
When replacing your keyboard make sure that you are not to rough with the removal of the keyboard. Take your time and go slowly or you will run the risk of damaging the laptop. Replacing your keyboard can help with efficiency and make working on your leptop more productive.
O que você precisa
Remove the four F4 screws and the F6 screw underneath battery.
4mm Phillips-0 screws.
6mm Phillips-0 screws.
Uma outra pessoa concluiu este guia.
