Ir para o conteúdo principal
Toshiba NB305 Keyboard Replacement
O que você precisa
  1. Toshiba NB305 Keyboard  Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: passo 2, imagem 1 %32
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: passo 3, imagem 1 %32 Toshiba NB305 Keyboard  Replacement: passo 3, imagem 2 %32
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: passo 4, imagem 1 %32 Toshiba NB305 Keyboard  Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: passo 5, imagem 1 %32 Toshiba NB305 Keyboard  Replacement: passo 5, imagem 2 %32 Toshiba NB305 Keyboard  Replacement: passo 5, imagem 3 %32
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: passo 6, imagem 1 %32 Toshiba NB305 Keyboard  Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: passo 7, imagem 1 %32
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: passo 8, imagem 1 %32 Toshiba NB305 Keyboard  Replacement: passo 8, imagem 2 %32
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
Conclusão
Uma outra pessoa concluiu este guia.
Nuri Chung
Membro desde: 10/25/16
368 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 5-5, Lacy Fall 2016 Membro de USF Tampa, Team 5-5, Lacy Fall 2016
USFT-LACY-F16S5G5
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 690
