Ir para o conteúdo principal
Toshiba NB205 N330PK Speaker Removal
O que você precisa
  1. Toshiba NB205 N330PK Speaker Removal, Power Button: passo 1, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal, Power Button: passo 1, imagem 2 %32
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Speaker Removal: passo 2, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 2, imagem 2 %32
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Speaker Removal: passo 3, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 3, imagem 2 %32
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Speaker Removal: passo 4, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 4, imagem 2 %32
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Speaker Removal, Speaker: passo 5, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal, Speaker: passo 5, imagem 2 %32 Toshiba NB205 N330PK Speaker Removal, Speaker: passo 5, imagem 3 %32
    • Use the spudger to gently pry around the seam of the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Speaker Removal: passo 6, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 6, imagem 2 %32
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the keyboard assembly out and away from the netbook.
  7. Toshiba NB205 N330PK Speaker Removal: passo 7, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 7, imagem 2 %32
    • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
  8. Toshiba NB205 N330PK Speaker Removal: passo 8, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Pull the cable away from the connector in the same direction as the individual wires using your hands or tweezers.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use a spudger to gently pry the bezel from retaining clips.
    • This will allow the keyboard bezel to lift off of the body.
  9. Toshiba NB205 N330PK Speaker Removal: passo 9, imagem 1 %32
    • Use the pointed tip of a spudger to carefully push on each side of the speaker connector to release it. Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
  10. Toshiba NB205 N330PK Speaker Removal: passo 10, imagem 1 %32 Toshiba NB205 N330PK Speaker Removal: passo 10, imagem 2 %32
    • Use Phillips #0 screwdriver to remove the two retaining screws on the speaker assembly.
    • Lift out the old speaker assembly.
Conclusão
Mason McCaskill
Membro desde: 10/18/13
1.021 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-2, Benson Fall 2013 Membro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Membros
Autoria de 27 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 620
