Ir para o conteúdo principal
Toshiba NB205 N330PK RAM Replacement
O que você precisa
  1. Toshiba NB205 N330PK RAM Replacement, RAM: passo 1, imagem 1 %32 Toshiba NB205 N330PK RAM Replacement, RAM: passo 1, imagem 2 %32
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: passo 2, imagem 1 %32 Toshiba NB205 N330PK RAM Replacement: passo 2, imagem 2 %32 Toshiba NB205 N330PK RAM Replacement: passo 2, imagem 3 %32
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: passo 3, imagem 1 %32 Toshiba NB205 N330PK RAM Replacement: passo 3, imagem 2 %32
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: passo 4, imagem 1 %32 Toshiba NB205 N330PK RAM Replacement: passo 4, imagem 2 %32
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
Conclusão
Uma outra pessoa concluiu este guia.
Mason McCaskill
Membro desde: 10/18/13
1.000 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-2, Benson Fall 2013 Membro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 508
