Introdução
This step-by-step guide outlines how to replace the keyboard on the Toshiba NB205 N330PK. The guide will help to restore the connection by removing the battery, reestablishing the electrical connection, and reattaching or replacing the keyboard.
An out-of-date computer program may cause keyboard failure. However, if updating or clearing unused data from the device does not work, the issue lies in the computer’s external hardware, a physical component of the device. After extended use, the keyboard’s electrical connection will falter, resulting in the laptop display registering some or no keyboard inputs.
Upon completing this repair, you can restore your keyboard’s electrical connection. Before starting the repair, power down the device and disconnect any external power sources to start battery removal.
O que você precisa
Start by first removing the battery.
Move the first release switch to the right position.
Move the second release switch to the right position while pulling the battery towards the top of the netbook.
Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
Uma outra pessoa concluiu este guia.
