Ir para o conteúdo principal
Toshiba NB205 N330PK Key Cleaning
O que você precisa
  1. Toshiba NB205 N330PK Key Cleaning, Toshiba NB205 N330PK Key Cleaning: passo 1, imagem 1 %32
    • Using the spudger, gently pry the desired key up on one side. This will release the key.
    • The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
  2. Toshiba NB205 N330PK Key Cleaning: passo 2, imagem 1 %32 Toshiba NB205 N330PK Key Cleaning: passo 2, imagem 2 %32
    • Use a brush to remove debris and use a cleaner cloth to remove residue.
    • Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
  3. Toshiba NB205 N330PK Key Cleaning: passo 3, imagem 1 %32
    • Once clean, set the key above its original position and firmly press it back into place.
    • If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
Conclusão
This is a complete guide to removing a key and cleaning the area before replacement.
Mason McCaskill
Membro desde: 10/18/13
1.021 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-2, Benson Fall 2013 Membro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 525
