Ir para o conteúdo principal
Toshiba NB205 N330PK Battery Replacement
O que você precisa
  1. Toshiba NB205 N330PK Battery Replacement, Battery: passo 1, imagem 1 %32
    • To release the battery, first slide the switch to the right.
  2. Toshiba NB205 N330PK Battery Replacement: passo 2, imagem 1 %32
    • Use your right hand to slide the second release switch to the right to unlock the battery.
    • Simultaneously, use your left hand to pull the battery towards the top of the netbook.
  3. Toshiba NB205 N330PK Battery Replacement: passo 3, imagem 1 %32 Toshiba NB205 N330PK Battery Replacement: passo 3, imagem 2 %32
    • With a soft or medium bristle brush, gently remove debris from the battery's contacts.
    • Similarly, remove debris from the matching contacts on the netbook itself.
    • Ensure hands and brush are dry to prevent personal injury from electric shock.
  4. Toshiba NB205 N330PK Battery Replacement: passo 4, imagem 1 %32 Toshiba NB205 N330PK Battery Replacement: passo 4, imagem 2 %32
    • To reconnect the battery, align these hooks with the designated holes on the netbook.
    • Firmly press the battery back into its original position. A clicking noise should be heard as the switch (bottom switch in photo's orientation) automatically moves.
  5. Toshiba NB205 N330PK Battery Replacement: passo 5, imagem 1 %32
    • Move the switch to the left position to secure the battery and lock it in place. This ensure a strong battery connection and prevents battery from falling out.
Conclusão
Follow this guide from beginning to end for battery removal, replacement, and cleaning.
Uma outra pessoa concluiu este guia.
Mason McCaskill
Membro desde: 10/18/13
1.000 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-2, Benson Fall 2013 Membro de Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 813
