Introdução
Hello, in this simple guide I’ll be showing you how to replace the keyboard of Toshiba NB100 laptop.
O que você precisa
Remove the 3 screws holding the panel above the keyboard. The third one should be below the battery, so remove it as well
Use a spudger to pop the panel and remove it.
Remove the 2 screws holding the keyboard in place.
Carefully lift the keyboard and gently disconnect the cable.
Thats it. Remove the old keyboard and replace it with the new one.
Uma outra pessoa concluiu este guia.
