Ir para o conteúdo principal
Toshiba Mini NB505 Keyboard Replacement
O que você precisa
  1. Toshiba Mini NB505 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Located on the bottom of the laptop, find the two tabs shown in the picture and push both of them outwards away from the battery.
  2. Toshiba Mini NB505 Keyboard Replacement: passo 2, imagem 1 %32
    • While pushing the tabs outwards, push on the raised bumps on the battery away from the laptop.
  3. Toshiba Mini NB505 Keyboard Replacement: passo 3, imagem 1 %32
    • The battery is now removed
  4. Toshiba Mini NB505 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Locate the five 1.2 mm Phillips # 000 screws inside of the battery housing.
  5. Toshiba Mini NB505 Keyboard Replacement: passo 5, imagem 1 %32
    • Using a Phillips head #000 screwdriver, carefully remove the five 1.2mm screws.
  6. Toshiba Mini NB505 Keyboard Replacement: passo 6, imagem 1 %32
    • Use a plastic pry tool to pop the tab holding the keyboard to the laptop.
  7. Toshiba Mini NB505 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Mini NB505 Keyboard Replacement: passo 7, imagem 2 %32
    • Remove plastic plate above keyboard.
  8. Toshiba Mini NB505 Keyboard Replacement: passo 8, imagem 1 %32
    • Lift the keyboard gently away from the computer.
    • Do not attempt to fully remove the keyboard, as it is attached to the laptop by a ribbon cable.
  9. Toshiba Mini NB505 Keyboard Replacement: passo 9, imagem 1 %32 Toshiba Mini NB505 Keyboard Replacement: passo 9, imagem 2 %32 Toshiba Mini NB505 Keyboard Replacement: passo 9, imagem 3 %32
    • Locate the ribbon wire under the keyboard. Slide the white tabs forward and the keyboard will come loose.
Conclusão
3 outras pessoas executaram este guia.
Owen Velho
Membro desde: 03/09/16
508 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 7-7, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-7, Catania Spring 2016
UMASSD-CATANIA-S16S7G7
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 1,404
