Ir para o conteúdo principal
Toshiba HD-A2 Power Button Replacement
O que você precisa
  1. Toshiba HD-A2 Power Button Replacement, Power Button: passo 1, imagem 1 %32 Toshiba HD-A2 Power Button Replacement, Power Button: passo 1, imagem 2 %32 Toshiba HD-A2 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: passo 2, imagem 1 %32
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: passo 3, imagem 1 %32 Toshiba HD-A2 Power Button Replacement: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: passo 4, imagem 1 %32
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
Conclusão
Nouriyah Saleh
Membro desde: 10/22/18
800 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team S11-G1, Lore Fall 2018 Membro de UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 46
Ao todo: 339
