Ir para o conteúdo principal
Toshiba HD-A2 Optical Drive Replacement
O que você precisa
  1. Toshiba HD-A2 Optical Drive Replacement, Top Panel: passo 1, imagem 1 %32
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Optical Drive Replacement: passo 2, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 2, imagem 2 %32
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Optical Drive Replacement: passo 3, imagem 1 %32
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Optical Drive Replacement, Optical Drive: passo 4, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement, Optical Drive: passo 4, imagem 2 %32 Toshiba HD-A2 Optical Drive Replacement, Optical Drive: passo 4, imagem 3 %32
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Optical Drive Replacement: passo 5, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 5, imagem 2 %32
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Optical Drive Replacement: passo 6, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 6, imagem 2 %32 Toshiba HD-A2 Optical Drive Replacement: passo 6, imagem 3 %32
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Optical Drive Replacement: passo 7, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 7, imagem 2 %32
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Optical Drive Replacement: passo 8, imagem 1 %32
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Optical Drive Replacement: passo 9, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 9, imagem 2 %32
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Optical Drive Replacement: passo 10, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 10, imagem 2 %32
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Optical Drive Replacement: passo 11, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 11, imagem 2 %32
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Optical Drive Replacement: passo 12, imagem 1 %32 Toshiba HD-A2 Optical Drive Replacement: passo 12, imagem 2 %32 Toshiba HD-A2 Optical Drive Replacement: passo 12, imagem 3 %32
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Nouriyah Saleh
Membro desde: 10/22/18
800 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team S11-G1, Lore Fall 2018 Membro de UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 392
