Ir para o conteúdo principal
Toshiba Excite 7 Battery Replacement
O que você precisa
  1. Toshiba Excite 7 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Excite 7 Battery Replacement, Battery: passo 1, imagem 2 %32 Toshiba Excite 7 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Battery Replacement: passo 2, imagem 1 %32 Toshiba Excite 7 Battery Replacement: passo 2, imagem 2 %32
    • Remove any black tape from the device.
    • Keep the tape; you will need to put it back on when you are done.
  3. Toshiba Excite 7 Battery Replacement, Unplug Wires: passo 3, imagem 1 %32 Toshiba Excite 7 Battery Replacement, Unplug Wires: passo 3, imagem 2 %32
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it: one just above the battery and one just to the right.
  4. Toshiba Excite 7 Battery Replacement, remove screws: passo 4, imagem 1 %32 Toshiba Excite 7 Battery Replacement, remove screws: passo 4, imagem 2 %32
    • Remove the five screws from the battery.
  5. Toshiba Excite 7 Battery Replacement: passo 5, imagem 1 %32 Toshiba Excite 7 Battery Replacement: passo 5, imagem 2 %32
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery; they may fall off.
    • Push the clip back then lift the battery up.
Conclusão
4 outras pessoas executaram este guia.
osmel fermin
Membro desde: 01/15/15
176 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Tanski Winter 2015 Membro de USF Tampa, Team 1-3, Tanski Winter 2015
USFT-TANSKI-W15S1G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 36
Ao todo: 1,961
