Ir para o conteúdo principal
Toshiba Excite 10 AT300 Battery Replacement
O que você precisa
  1. Toshiba Excite 10 AT300 Battery Replacement, Remove SD Card: passo 1, imagem 1 %32
    • Remove the SD card from the SD card slot.
  2. Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: passo 2, imagem 1 %32 Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: passo 2, imagem 2 %32 Toshiba Excite 10 AT300 Battery Replacement, Open the Tablet: passo 2, imagem 3 %32
    • Use the opening tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
    • Make sure you unclip all of the clips on the back panel, or pulling it off will be difficult and may damage the tablet.
  3. Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: passo 3, imagem 1 %32 Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: passo 3, imagem 2 %32 Toshiba Excite 10 AT300 Battery Replacement, Disconnect Speaker Wires: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the speaker cable from its socket by gripping both sides of the white connector piece with tweezers and pulling straight out.
    • Be careful not to rip the wires out of the white connector piece.
  4. Toshiba Excite 10 AT300 Battery Replacement, Remove Screws: passo 4, imagem 1 %32 Toshiba Excite 10 AT300 Battery Replacement, Remove Screws: passo 4, imagem 2 %32
    • Using a #00 Phillips screwdriver, remove the following screws:
    • Five 3mm Phillips #00 screws
  5. Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: passo 5, imagem 1 %32 Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: passo 5, imagem 2 %32 Toshiba Excite 10 AT300 Battery Replacement, Remove Battery Cable: passo 5, imagem 3 %32
    Comprar
    • Gently lift the battery, pulling away from the tab holding it in place at the bottom.
    • While holding the battery up, use a pair of tweezers to remove the battery cable from its connector.
Conclusão
12 outras pessoas executaram este guia.
Andrew Gillis
Membro desde: 10/09/14
564 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 14-26, Maness Fall 2014 Membro de Cal Poly, Team 14-26, Maness Fall 2014
CPSU-MANESS-F14S14G26
Membros da 4
Autoria de 12 guias
5 comentários
My tablet won't come on what do i do? It was working yesterday with no problem when I plugged it in this morning to charge it while I was gone when I came back it would come on at all . It felt hot.
lajenaolson - Responder
Thank you kindly. It took 20 minutes total.
Jamie Kitchens - Responder
My tablet comes but it's want to go to main screen
Sylvia Chambers - Responder
How do I get another battery for my Toshiba tablet
Tracy - Responder
Ça m'a pris 20 min.La batterie est HS.Comment la brancher directement sur électricité ???!!?
Josephen Zacchari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 18,692
